BDLs EVO9S is the work horse of belt drives. With over 50 000 kits running on bikes today you can be reassured this drive can outlast and out perform the competition. Our onepiece 6061T6 polished billet motor plate locks the trans and engine together. All of these kits include a 3 wide belt drive unit with polished pressure plate,double row sealed mainshaft bearing,polished aluminum side plate and pulley covers and a complete BDL Clutch with Kevlar plates. For installation in wide frametire applications,choose the appropriate insert. For Softail Models from 19902006.ID DESCRIPTION PART NO.A Rear Basket breakdown below 723EB 47 Tooth Front Pulley breakdown below 47OFPC 3 HTD Rubber Belt BDL1413D Clutch Hub EV180E Complete Clutch Kit inc. fibers and steels ERCPS100F Spring Pressure Plate EPP100G Hub Nut with Seal HNS100H Adjusting Screw and Nut CDAS100I Shoulder Bolts Set of 9 ESB100J Coil Springs ECS100K Front Pulley Nut,Washer FHN2,WA3L Hardware kit for EVO9S HK9M Softail Motor Plate MP9N Starter Housing SH9AO Side Plate SP9P Dome Covers MD100Q Starter Pinion Gear PG100
